It is currently Thu Aug 21, 2025 8:32 pm
PostPosted: Wed Oct 09, 2013 2:16 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I went to the lumberyard and picked out this piece which I got 3 jumbo sized sets out of. I paid 60 dollars total for the plank. Supplier says it's bubinga but I want to be sure because it doesn't look like the bubinga I remember. The density is measured to be around 0.6 or so (but I could be off because I'm doing a very imprecise measurement) and the grain is very straight. This is the back side I rubbed some mineral oil into to show you what it looks like. It's not as "red" as the bubinga I first worked on and the wood is hard, but not so hard that I had much trouble resawing it. When I first saw the wood I thought it was mahogany but it's heavier than mahogany but not heavy like Padauk. It also did not have the grain structure of any mahogany I have ever seen. Can anyone confirm if this is in fact bubinga? Note it was freshly sawn and the old surface is darker for sure... It has the color of bubinga but it does not look quite as pink (when unfinished) as bubinga I get from LMI. However it does look "right" from the wood database pictures...
Typhoon Guitars
PostPosted: Wed Oct 09, 2013 6:30 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
That doesn't look like any Bubinga I've seen, but is your white balance off?
Bubinga is as dense, or denser than Padauk. I also think it stinks when working it.
Kevin Looker
I'm not a luthier.
PostPosted: Wed Oct 09, 2013 6:48 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It doesn't smell too good when working with it for sure... not nearly as pleasant as padauk. It's a little worse than mahogany but I know it's not mahogany because it's much harder and more brittle than mahogany. The light in the room is yellow so it may have thrown the balance off a bit...
The wood seems to leech some of its resin when wetted, giving a frothy appearance when I wipe the water off. I'm not sure what it is now... the lumberyard called it "African redwood" but it sure doesn't look like any bubinga I've seen. The wood has more of an orange-brown color when wetted than bubinga for sure.
Here is more picture to help... The wood really wants to bend, as in it's not very stiff at all. I've only thinned it to .09" and the wood just flops around like crazy.
Typhoon Guitars
PostPosted: Wed Oct 09, 2013 7:22 am
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Zip/Postal Code: 30705
Definitely not bubinga. Possibly sapele or jatoba.
Guitar Maker and Purveyor of the World's Finest Tonewoods
http://www.aaronhixguitars.com/
http://stores.ebay.com/A-Hix-Tonewood-a ... r-Supplies
PostPosted: Wed Oct 09, 2013 7:34 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I know it can't be sapele because I have bought sapele from them before... and they have very distinct ribbon figure and the grain line is also different. Sapele is also fairly soft, enough that it's really easy to resaw and carve. This wood has about the same hardness as maple.
Now I'm really stumped... I've searched espen.de and they have bubinga sets that looks very close to this particular example so it's probably bubinga. I didn't really overpay for it because it's about the same per board foot as mahogany/sapele.
Typhoon Guitars
PostPosted: Wed Oct 09, 2013 9:13 am
Nato.
PostPosted: Wed Oct 09, 2013 9:21 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Are you sure it's nato? I'm not even sure the lumberyard stocked it. It doesn't work like mahogany and I was under the impression that nato is quite a bit lighter, and this wood is fairly dense, more dense than mahogany or sapele but not as much as padauk. I cut it into backs/sides because the wood has straight grain, doesn't look bad, is hard, has decent tap tone (rings a bit when I tap it, even as a solid block) and wasn't too expensive. It's going into prototype guitars because previously I wanted to resaw some of the maple planks I have, however none of them are wide enough to make even an OM.
Update: I measured the density more precisely this time and it comes to around 0.72g per cubic centimeter, so it's in the rosewood range, and out of the density range of nato (unless this is a heavy example of nato), it's also much harder than mahogany (I realized this as I was writing on the wood with a pencil): I can easily dent mahogany writing on it with a blunt pencil but this one is like writing on stone. The Wagner Safe T Planer also had a bit of a trouble planing this wood... the drill press would slow down when taking a full width cut and as a result burned the wood a little bit. It could cut even Indian rosewood fairly well and it cuts mahogany like butter. The woodmaster CT of course was able to cut the wood without much trouble but I got some squealing (with the ripple pattern to show) on the cut which shows the wood is definitely not anything resembling mahogany. The lumber yard resawn it in half for me (so I can divide it up into backs and sides, since the wood was really thick and I wanted to maximize yield out of this wood) and their 36" bandsaw and 3" carbon steel blade cut through this wood literally like butter, with very smooth cuts that are only a little worse than the woodmaster CT.
I have a few ideas:
If it's not bubinga (or a very plain/straight grained version of bubinga) I am thinking it could be a Taiwanese wood known as 烏心石 in chinese (pinyin wu xin shi) which is fairly hard, has decent grains and is used to make premium furniture in Taiwan. The wood certainly looks a lot like it and if so it would be a really interesting thing to see how the guitar will sound.
Typhoon Guitars
PostPosted: Wed Oct 09, 2013 11:37 am
Hello,
can you provide more, better pictures?
Cheers, Alex
PostPosted: Wed Oct 09, 2013 11:50 am
First name: Ringo
Your picture from this post looks like bubinga to me.
PostPosted: Wed Oct 09, 2013 12:04 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Here are some better pictures:
One picture is of the back, one side of the back is wetted. The wood at this thickness is very sensitive to moisture so as soon as I wetted it the wood started cupping away from the wet side. It equalizes as soon as the water dries however. Other than that the wood is incredibly straight and stable... in fact I was able to resaw it into 3 sets just from the rough sawn state because there was little discernible movement. The resulting piece moved very slightly but quickly straightened itself out as soon as the moisture content equalized. I don't expect to have the back assembled for a while... instead will concentrate on bending the side and making the top.
The other three photos are of the end grain, magnified as much as I can. I hope this will help.
Typhoon Guitars
PostPosted: Wed Oct 09, 2013 3:22 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
That looks like Bubinga to me. I have it all over my house one of my favorite woods.
PostPosted: Wed Oct 09, 2013 3:47 pm
First name: Christophe
Last Name: Mineau
City: Louannec
State: Brittany
Zip/Postal Code: 22700
Country: France
Hi ,
Possibly Aniegre ? (I think it's Anigre in english ?)
Christophe Mineau
Let's make chips ! - http://www.labellenote.fr
PostPosted: Thu Oct 10, 2013 8:23 am
First name: Tony
Last Name: C
City: Brooklyn
Definitely not a goat. I'm certain of that.
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Oct 10, 2013 10:47 am
A goat would smell much worse than described, especially if it was wet.
PostPosted: Thu Oct 10, 2013 2:40 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Now, if it were roasting on a spit, basted with lemon and garlic....
Alex
Users browsing this forum: Darrel Friesen and 25 guests
